[Qgis-user] Geo Referencing - The image does not fall in the right place
    Ujaval Gandhi
    ujaval at spatialthoughts.com
    Tue Apr 20 11:16:07 PDT 2021
Hi Krishna,
You are using the deprecated tutorial and as mentioned at top of the the
page, the updated tutorial is at the following link and works with QGIS
3.16 https://www.qgistutorials.com/en/docs/3/georeferencing_basics.html
Ujaval Gandhi
Spatial Thoughts
On Tue, Apr 20, 2021, 10:22 PM Jeff Sonnentag <jsonnentag at llenviroinc.com>
wrote:
> If you are using QGIS 3.16 then this reference is supposed to be the
> latest instructions:
> https://docs.qgis.org/3.16/en/docs/user_manual/working_with_raster/georeferencer.html
> I have had a similar problem in the past but it generally works if you set
> the Georeferencing SRS in the Georeferencer Transformation Settings to the
> map’s current CRS (shown in the bottom left corner of the map).
> *From:* Qgis-user <qgis-user-bounces at lists.osgeo.org> * On Behalf Of *krishna
> Ayyala
> *Sent:* Tuesday, April 20, 2021 8:16 AM
> *To:* qgis-user <qgis-user at lists.osgeo.org>
> *Subject:* [Qgis-user] Geo Referencing - The image does not fall in the
> right place
> Hello,
> I have a jpeg image that I georeferenced using the steps mentioned in the
> following link. At the end, the image does not fall in the right place. As
> shown in step13, a modified image is created and saved in the folder. This
> modified image layer name appears in the layers panel of QGIS but the image
> does not appear on the map.
> Regards.
> https://www.qgistutorials.com/en/docs/georeferencing_basics.html
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210420/a9a43b22/attachment.html>
