[Qgis-user] GPX group, add field "name" from track layer to attribut table point layer
APM
apschwimmer at apmland.de
Sun Apr 25 05:07:29 PDT 2021
Dear List,
if I import a gpx file via "Data source manager", I get a group with two
layers:
1. "track_points" as PointZ layer
2. "tracks" as MultiLineStringZ
The "tracks" layer contains a field "name" in the attribute table.
This field is not in the "track_points layer".
Is there a way to add the field "name" in the "track_point" layer, so
that every point has the track name which he belongs to?
I need this to create a map with hiking signs of the tracks. I use the
field "name" to get the relation between hiking signs and the tracks.
Basically it works, but I have overlapping SVG signs in the map.
To avoid this overlapping, I try to use the "point displacement" in the
"Symbology" menu. But I'm not sure if it will work. Maybe there is a
better way to avoid the overlapping.
Thank you for you help!
KR
Piet
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210425/b3708d37/attachment.html>
