[Qgis-user] Windows BATCH-File Start
    Burghardt.Scholle at stadt.wolfsburg.de
    Sun Apr 25 22:09:36 PDT 2021
Hi Asmus,
I think on Windows 10 you need to prefix your command with "C:\Windows\System32\cmd.exe".
Hope this helps.
Regards
Burghardt
Von: Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] Im Auftrag von Asmus Harder
Gesendet: Freitag, 23. April 2021 13:41
An: qgis-user at lists.osgeo.org
Betreff: [Qgis-user] Windows BATCH-File Start
Hi there,
I tried to use in QGIS 3.16 on Windows10 a old layer-action from QGIS 2.18.
If I cklick on one object the action should start an BATCH-file and gives some attributes as parameter to the batch-file. But it doesn't work, nothing happens.
In QGIS2.18 it works fine.
If I use "Open" as type and only the BATCH-File without parameter than the BATCH opens. If I add an parameter than nothing happens.
For example this work:
"d:\Test_Batch_Aufruf.bat"
but this doesn't work:
"d:\Test_Batch_Aufruf.bat" "Hello"
If I use a exe-file it works with a parameter.
For example this work fine:
"c:\Program Files\IrfanView\i_view64.exe" "D:\50342_col.tif"
Any idea why the BATCH-file doesn't start with parameter?
greetings
Asmus
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210426/aa5028fd/attachment.html>
