[Qgis-user] Windows BATCH-File Start
asmus.lists at gmx.de
Mon Apr 26 22:14:40 PDT 2021
Thanks Burghardt,
no, it don't work. It is still not posible to start a batch file with
some paramter as a layer-action.
Any other hints?
Regards
Asmus
Am 26.04.2021 um 07:09 schrieb Burghardt.Scholle at stadt.wolfsburg.de:
> Hi Asmus,
> I think on Windows 10 you need to prefix your command with
> "C:\Windows\System32\cmd.exe".
> Hope this helps.
> Regards
> Burghardt
> *Von:*Qgis-user [mailto:qgis-user-bounces at lists.osgeo.org] *Im Auftrag
> von *Asmus Harder
> *Gesendet:* Freitag, 23. April 2021 13:41
> *An:* qgis-user at lists.osgeo.org
> *Betreff:* [Qgis-user] Windows BATCH-File Start
> Hi there,
> I tried to use in QGIS 3.16 on Windows10 a old layer-action from QGIS
> 2.18.
> If I cklick on one object the action should start an BATCH-file and
> gives some attributes as parameter to the batch-file. But it doesn't
> work, nothing happens.
> In QGIS2.18 it works fine.
> If I use "Open" as type and only the BATCH-File without parameter than
> the BATCH opens. If I add an parameter than nothing happens.
> For example this work:
> "d:\Test_Batch_Aufruf.bat"
> but this doesn't work:
> "d:\Test_Batch_Aufruf.bat" "Hello"
> If I use a exe-file it works with a parameter.
> For example this work fine:
> "c:\Program Files\IrfanView\i_view64.exe" "D:\50342_col.tif"
> Any idea why the BATCH-file doesn't start with parameter?
> greetings
> Asmus
