[Qgis-user] Expression to read field value from composer layout?
    Stefan Giese (WhereGroup)
    stefan.giese at wheregroup.com
    Wed Aug  4 05:51:07 PDT 2021
here is a function which does the job. It's a bit more generic, you have
to pass the layoutname and the itemID to get the text:
/from qgis.core import *//
//from qgis.gui import *//
//@qgsfunction(args='auto', group='Custom')//
//def get_layout_textitem(layoutTitle, itemId, feature, parent)://
//    Gets the text from a labelitem in the layout with the name
layoutTitle.//
//    <h2>Example usage:</h2>//
//    <ul>//
//      <li>get_layout_textitem('Layout 1', 'text1') -> 'lorem ipsum</li>//
//    </ul>//
//    project = QgsProject.instance()//
//    projectLayoutManager = project.layoutManager()//
//    layout = projectLayoutManager.layoutByName(layoutTitle)//
//    fileNameLabel = layout.itemById(itemId)//
//    fileNameText = fileNameLabel.text() //
//    return fileNameText/
Am 04.08.2021 um 14:06 schrieb Patrick Dunford:
> layoutTitle = "Landscape 16:9 Header Nav Copyright Filename 2021"
> fileNameLabel = layout.itemById('Filename')
Mit freundlichen Grüßen
Stefan Giese
Projektleiter/Consultant
Aufbau von Geodateninfrastrukturen mit Open-Source-Software
FOSS Academy 5 Tage-Kompaktkurs „Sommerschule 2021“
Jetzt anmelden: https://foss-academy.com/kompaktkurse/
WhereGroup GmbH
Schwimmbadstr. 2
79100 Freiburg
Germany
Fon: +49 (0)761 / 519 102 - 61
Fax: +49 (0)761 / 519 102 - 11
www.wheregroup.com
Geschäftsführer:
Olaf Knopp, Peter Stamm
Amtsgericht Bonn, HRB 9885
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210804/15c11961/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210804/15c11961/attachment.png>
