[Qgis-user] Expression to read field value from composer layout?
Patrick Dunford
enzedrailmaps at gmail.com
Wed Aug 4 17:28:26 PDT 2021
Thanks for that. I also found a tutorial by Nathan Woodrow which
explains how to do custom functions.
https://woostuff.wordpress.com/2015/05/21/accessing-composer-item-properties-via-custom-expressions-in-qgis/
On 5/08/21 12:51 am, Stefan Giese (WhereGroup) wrote:
> here is a function which does the job. It's a bit more generic, you
> have to pass the layoutname and the itemID to get the text:
> /from qgis.core import *//
> //from qgis.gui import *//
> //@qgsfunction(args='auto', group='Custom')//
> //def get_layout_textitem(layoutTitle, itemId, feature, parent)://
> // Gets the text from a labelitem in the layout with the name
> layoutTitle.//
> // <h2>Example usage:</h2>//
> // <ul>//
> // <li>get_layout_textitem('Layout 1', 'text1') -> 'lorem
> ipsum</li>//
> // </ul>//
> // project = QgsProject.instance()//
> // projectLayoutManager = project.layoutManager()//
> // layout = projectLayoutManager.layoutByName(layoutTitle)//
> // fileNameLabel = layout.itemById(itemId)//
> // fileNameText = fileNameLabel.text() //
> // return fileNameText/
> Am 04.08.2021 um 14:06 schrieb Patrick Dunford:
>> layoutTitle = "Landscape 16:9 Header Nav Copyright Filename 2021"
>> fileNameLabel = layout.itemById('Filename')
> Mit freundlichen Grüßen
> Stefan Giese
> Projektleiter/Consultant
> Aufbau von Geodateninfrastrukturen mit Open-Source-Software
> FOSS Academy 5 Tage-Kompaktkurs „Sommerschule 2021“
> Jetzt anmelden:https://foss-academy.com/kompaktkurse/
> WhereGroup GmbH
> Schwimmbadstr. 2
> 79100 Freiburg
> Germany
> Fon: +49 (0)761 / 519 102 - 61
> Fax: +49 (0)761 / 519 102 - 11
> stefan.giese at wheregroup.com
> www.wheregroup.com
> Geschäftsführer:
> Olaf Knopp, Peter Stamm
> Amtsgericht Bonn, HRB 9885
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210805/65dcedd3/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210805/65dcedd3/attachment.png>
