[Qgis-user] Exporting QGIS map to KML/KMZ
    Charles Dixon-Paver
    charles at kartoza.com
    Thu Aug 12 15:58:20 PDT 2021
I think you may be able to use the kml tools plugin to achieve your desired
result
On Thu, 12 Aug 2021, 22:55 krishna Ayyala, <ayyalakrishna at gmail.com> wrote:
> Hello,
> I have a QGIS map saved with ".qgz" extension. This map has four layers.
> One layer has points, one layer has lines and two layers have polygons. Is
> it possible to convert the entire map to kmz without losing the symbology.
> I know how to convert each layer into kmz. But, I am exploring to see if I
> can convert the entire map to kmz?
> Regards.
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210813/bdaba9a7/attachment.html>
