[Qgis-user] Exporting QGIS map to KML/KMZ
krishna Ayyala
ayyalakrishna at gmail.com
Thu Aug 12 16:34:48 PDT 2021
Charles,
Thanks for the reply. I have the KML tools plugin installed. In that there
is a tool called "Export KMZ". That lets me export each individual layer to
a kmz. But it does not export the entire map to kmz.
Regards.
On Thu, Aug 12, 2021 at 4:58 PM Charles Dixon-Paver <charles at kartoza.com>
wrote:
> I think you may be able to use the kml tools plugin to achieve your
> desired result
> On Thu, 12 Aug 2021, 22:55 krishna Ayyala, <ayyalakrishna at gmail.com>
> wrote:
>> Hello,
>> I have a QGIS map saved with ".qgz" extension. This map has four layers.
>> One layer has points, one layer has lines and two layers have polygons. Is
>> it possible to convert the entire map to kmz without losing the symbology.
>> I know how to convert each layer into kmz. But, I am exploring to see if I
>> can convert the entire map to kmz?
>> Regards.
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210812/7bf75ebd/attachment.html>
