[Qgis-user] QGIS "full" builds
Ari Meyer ari.meyer at gmail.com
Fri Aug 13 19:07:40 PDT 2021
One thing that is still unclear to me is the difference between the
qgis-*full* distributions and the corresponding builds that aren't "full".
Here is the only thing I could find (very old):
https://gis.stackexchange.com/questions/192978/installing-qgis-ltr-or-qgis-ltr-full-with-osgeo4w-or-both
, but it's still not clear what the difference is.  Do I need *full* to get
all the *necessary* dependencies?  That doesn't appear to be the case.
Will *full* install a lot of dependencies we don't necessarily need?
Unclear.  If I just install qgis-ltr and pick the additional dependencies I
need, it works.
So when do we want to use full?  It says in
https://qgis.org/en/site/forusers/download.html that we should just pick
qgis-ltr with the new V2 network installer, but we should pick
qgis-ltr-full with the old V1.  Is that right?  Very confusing.
>From the installation page:
QGIS in OSGeo4W (recommended for regular users):
  OSGeo4W Network Installer
In the installer choose Express Install and select QGIS to install the
latest release or QGIS LTR to install the long term release.
The express installations have several optional packages including non-free
software. To avoid those you have to use the Advanced Install and choose
qgis and/or qgis-ltr in the desktop section.
Long-term release in old OSGeo4W (continued with previous dependencies):
  OSGeo4W Network Installer (64 bit)
  OSGeo4W Network Installer (32 bit)
In the installer choose Advanced Install and select qgis-ltr-full to
So with the V2 installer, it says we should pick "qgis-ltr".  With V1,
though, it says that we should select "qgis-ltr-full".  Is that a mistake?
More confusing still, I tried several installs with the following criteria:
* Desktop
* qgis-ltr 3.16.9-1
* saga: SAGA
* Libs
* qgis-ltr-grass-plugin
* python3-geopandas
* python3-pip
* python3-scipy
* python3-setuptools
Here are the directory sizes for the different installations:
V1 installer:
qgis-ltr 3.16.9-1: 1,317,261,588b
qgis-ltr-full 3.10-2: unknown
V2 installer:
qgis-ltr 3.16.9-1: 2,611,070,436b
qgis-ltr-full 3.16.9-1: 2,364,040,539b
So with V2, with the same dependencies, qgis-ltr-full actually was
*smaller* than qgis-ltr!  The V1 3.16.9-1 qgis-ltr has Python 3.7 and older
dependencies, so I know we're not comparing apples to apples.  The V1
qgis-ltr-full still shows 3.10-2, so I didn't even bother installing it.
Do the V2 differences between qgis-ltr-full and qgis-ltr make sense?
Thanks,
Ari
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210813/137f2a9e/attachment.html>
