[Qgis-user] Layer Ordering for KMZ
krishna Ayyala ayyalakrishna at gmail.com
Sat Aug 14 09:23:45 PDT 2021
Dear Charles,
Thanks for your reply. I am attaching the sample data which contains the
shapefiles and the kmz file. There are four small points (A,B,C,D) that
should fall on top of four big points (E,F,G,H).
Each time I open the kmz, I am getting different results. One time I
donot see any of the small points. Another time I see one small point on
top of big points. Another time I see two small points on top of the big
points. Is there a way such that, anytime I open the kmz, I should
always see all the four small points on top of the big points.
Regards.
On Sat, Aug 14, 2021 at 8:42 AM Charles Dixon-Paver <charles at kartoza.com>
wrote:
> I think it's hard to assess without some sample data to evaluate.
> My suspicion would be that Google Earth is rendering it according to the
> feature elevations.
> When you export the KML you should have the option to set
> the clamptoGround/relativeToGround/Absolute for defining the altitude mode
> to see if it resolves the issue, otherwise you could export smaller points
> "relative" to make sure they render "above" the big points.
> Regards
> On Sat, 14 Aug 2021 at 16:30, krishna Ayyala <ayyalakrishna at gmail.com>
> wrote:
>> Dear Sir,
>> Thanks for your reply. I tried to rename the KML files and also the
>> shapefiles. I have re-named small points as "A_Smal_Points" and big points
>> as "B_Big_Points". But still "B_Big_Points" is falling on top of
>> "A_Smal_Points". My task requires "A_Smal_Points" to fall on top of
>> "B_Big_Points".
>> Regards.
>> On Fri, Aug 13, 2021 at 6:27 PM Fernando M. Roxo da Motta <petro at roxo.org>
>> wrote:
>>> On Fri, 13 Aug 2021 17:08:24 -0600, krishna Ayyala
>>> <ayyalakrishna at gmail.com> wrote:
>>>   Hi,
>>>   I don't really know the answer to your question, bu it really looks
>>> like GE is laying those in alphabetical order.   I don't know if the
>>> name is based in the file name or in some content of the file, but you
>>> could try to rename the .KML files or just the layers in Qgis before
>>> export.
>>>   Just my 2¢, HTH.
>>> > Hello,
>>> > I have a QGIS map with two vector point layers. Layer 1 is
>>> > "Small_Points" and Layer 2 is "Big_Points". I have the KML tool
>>> > plugin installed. I have exported each of these layers using "Export
>>> > KMZ" tool. Everything exported well including the symbology.
>>> > But When I add these two KMZ layers to the google earth, always
>>> > "Big_Points" layer appears on top of "Small_Points" layer. In the
>>> > table of contents, I tried to move "Small_Points" layer on top of
>>> > "Big_Points" layer. Despite of that  "Big_Points" layer appears on
>>> > top of "Small_Points" layer on the map. Can anyone help me fix this
>>> > such that "Small_Points" appear on top of "Big_Points".
>>> > Regards.
>>>   Roxo
>>> ---------------- Non luctari, ludare -------------------+ WYSIWYG
>>> Fernando M. Roxo da Motta <petro at roxo.org>              | Editor?
>>> Except where explicitly stated I speak on my own behalf.|  VI !!
>>>                 PU5RXO | PX5Q6048                       | I see text,
>>> ------------ Quis custodiet ipsos custodes?-------------+ I get text!
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210814/e44c6ba6/attachment.html>
Type: application/x-zip-compressed
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210814/e44c6ba6/attachment.bin>
