[Qgis-user] How to make a table in a subsection report
    Dario C
    dario955i at gmail.com
    Wed Aug 18 00:35:38 PDT 2021
I'm considering to make a custom page with the size of the form and then I
use Indesign or similar to compose everything.
Thank you for your reply
Il giorno mer 18 ago 2021 alle ore 09:05 Bernd Vogelgesang <
bernd.vogelgesang at gmx.de> ha scritto:
> I only faintly remember making a report last year with a similar problem
> (maps of photo destinations on different sections of a highway).
> I think I solved it by adding new columns of combined indices with the
> subsection (your grid) and the photo-id, because there way no way to do
> this within the report.
> Haven't touched the tool since then, cause every redecision on how to
> design the report lead to a complete new start from scratch, which took
> too much time.
> Not sure if it hits your problem. As I said, can't remember well.
> Good luck,
> Bernd
> On 18.08.21 08:53, Dario wrote:
> > Hi, I have a report with a primary dynamic section where I have a map
> with a controlled layer (indexed grid). Inside each map I have points
> (sometime one, sometime more).
> > I need to make a subsection with these points (each point has the same
> indexed grid name, so I can maintain the same order of the map).
> > The issue is it is requested to make two table (form) for each page and
> I don’t know if it is possible or not. I mean... what’s happen when I have
> only one table and how it recognise the sequence between first and second
> item in the same page?
> > Sorry if I was not so clear...
> > Thank you in advance for your help
> > Cheers
> > _
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210818/6fca032c/attachment.html>
