[Qgis-user] How to make a table in a subsection report
    Alexandre Neto
    senhor.neto at gmail.com
    Wed Aug 18 00:57:48 PDT 2021
Hello Dario,
Do you mean having the same attribute table divided in two columns?
If so. Yes, that is possible.
Alexandre Neto
User Support Team
www.qcooperative.net
A quarta, 18/08/2021, 08:37, Dario C <dario955i at gmail.com> escreveu:
> I'm considering to make a custom page with the size of the form and then I
> use Indesign or similar to compose everything.
> Thank you for your reply
> Il giorno mer 18 ago 2021 alle ore 09:05 Bernd Vogelgesang <
> bernd.vogelgesang at gmx.de> ha scritto:
>> I only faintly remember making a report last year with a similar problem
>> (maps of photo destinations on different sections of a highway).
>> I think I solved it by adding new columns of combined indices with the
>> subsection (your grid) and the photo-id, because there way no way to do
>> this within the report.
>> Haven't touched the tool since then, cause every redecision on how to
>> design the report lead to a complete new start from scratch, which took
>> too much time.
>> Not sure if it hits your problem. As I said, can't remember well.
>> Good luck,
>> Bernd
>> On 18.08.21 08:53, Dario wrote:
>> > Hi, I have a report with a primary dynamic section where I have a map
>> with a controlled layer (indexed grid). Inside each map I have points
>> (sometime one, sometime more).
>> > I need to make a subsection with these points (each point has the same
>> indexed grid name, so I can maintain the same order of the map).
>> > The issue is it is requested to make two table (form) for each page and
>> I don’t know if it is possible or not. I mean... what’s happen when I have
>> only one table and how it recognise the sequence between first and second
>> item in the same page?
>> > Sorry if I was not so clear...
>> > Thank you in advance for your help
>> > Cheers
>> > _
>> > _______________________________________________
>> > Qgis-user mailing list
>> > Qgis-user at lists.osgeo.org
>> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210818/fb07fc57/attachment-0001.html>
