[Qgis-user] How to make a table in a subsection report
    Dario C
    dario955i at gmail.com
    Thu Aug 19 01:43:29 PDT 2021
Thank you Alexandre. I'm working on it because it is a little bit complex
to explain without any image. When I finish, I could bother you again :)
Il giorno mer 18 ago 2021 alle ore 09:58 Alexandre Neto <
senhor.neto at gmail.com> ha scritto:
> Hello Dario,
> Do you mean having the same attribute table divided in two columns?
> If so. Yes, that is possible.
> Alexandre Neto
> User Support Team
> www.qcooperative.net
> A quarta, 18/08/2021, 08:37, Dario C <dario955i at gmail.com> escreveu:
>> I'm considering to make a custom page with the size of the form and then
>> I use Indesign or similar to compose everything.
>> Thank you for your reply
>> Il giorno mer 18 ago 2021 alle ore 09:05 Bernd Vogelgesang <
>> bernd.vogelgesang at gmx.de> ha scritto:
>>> I only faintly remember making a report last year with a similar problem
>>> (maps of photo destinations on different sections of a highway).
>>> I think I solved it by adding new columns of combined indices with the
>>> subsection (your grid) and the photo-id, because there way no way to do
>>> this within the report.
>>> Haven't touched the tool since then, cause every redecision on how to
>>> design the report lead to a complete new start from scratch, which took
>>> too much time.
>>> Not sure if it hits your problem. As I said, can't remember well.
>>> Good luck,
>>> Bernd
>>> On 18.08.21 08:53, Dario wrote:
>>> > Hi, I have a report with a primary dynamic section where I have a map
>>> with a controlled layer (indexed grid). Inside each map I have points
>>> (sometime one, sometime more).
>>> > I need to make a subsection with these points (each point has the same
>>> indexed grid name, so I can maintain the same order of the map).
>>> > The issue is it is requested to make two table (form) for each page
>>> and I don’t know if it is possible or not. I mean... what’s happen when I
>>> have only one table and how it recognise the sequence between first and
>>> second item in the same page?
>>> > Sorry if I was not so clear...
>>> > Thank you in advance for your help
>>> > Cheers
>>> > _
>>> > _______________________________________________
>>> > Qgis-user mailing list
>>> > Qgis-user at lists.osgeo.org
>>> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210819/5b30d9b2/attachment.html>
