[Qgis-user] How to make a table in a subsection report
Dario C dario955i at gmail.com
Fri Aug 20 01:34:45 PDT 2021
Hi, here in attachment a very rough sample.
This section is following the dot layer "telecamere", where I have a field
with the name of the gridname where they are. Of course I can have one or
multiple point in the same grid.
I have a small map (repetition of the main page and section), a picture
(I'm studying how to make it in a report, and a description form when I've
just transposed the records.
At the moment I have solved making a custom page (1/3 of A3 size), so I
have all the forms in each separated page and at the end I will compose
them using other software (PowerPoint, InDesign, whatever). I know, very
dummy way :)
Now, using this expression (of course), if I copy three times this form in
a full A3 format I don't have three different records, but always the same.
thanks
Il giorno gio 19 ago 2021 alle ore 10:43 Dario C <dario955i at gmail.com> ha
scritto:
> Thank you Alexandre. I'm working on it because it is a little bit complex
> to explain without any image. When I finish, I could bother you again :)
> Il giorno mer 18 ago 2021 alle ore 09:58 Alexandre Neto <
> senhor.neto at gmail.com> ha scritto:
>> Hello Dario,
>> Do you mean having the same attribute table divided in two columns?
>> If so. Yes, that is possible.
>> Alexandre Neto
>> User Support Team
>> www.qcooperative.net
>> A quarta, 18/08/2021, 08:37, Dario C <dario955i at gmail.com> escreveu:
>>> I'm considering to make a custom page with the size of the form and then
>>> I use Indesign or similar to compose everything.
>>> Thank you for your reply
>>> Il giorno mer 18 ago 2021 alle ore 09:05 Bernd Vogelgesang <
>>> bernd.vogelgesang at gmx.de> ha scritto:
>>>> I only faintly remember making a report last year with a similar problem
>>>> (maps of photo destinations on different sections of a highway).
>>>> I think I solved it by adding new columns of combined indices with the
>>>> subsection (your grid) and the photo-id, because there way no way to do
>>>> this within the report.
>>>> Haven't touched the tool since then, cause every redecision on how to
>>>> design the report lead to a complete new start from scratch, which took
>>>> too much time.
>>>> Not sure if it hits your problem. As I said, can't remember well.
>>>> Good luck,
>>>> Bernd
>>>> On 18.08.21 08:53, Dario wrote:
>>>> > Hi, I have a report with a primary dynamic section where I have a map
>>>> with a controlled layer (indexed grid). Inside each map I have points
>>>> (sometime one, sometime more).
>>>> > I need to make a subsection with these points (each point has the
>>>> same indexed grid name, so I can maintain the same order of the map).
>>>> > The issue is it is requested to make two table (form) for each page
>>>> and I don’t know if it is possible or not. I mean... what’s happen when I
>>>> have only one table and how it recognise the sequence between first and
>>>> second item in the same page?
>>>> > Sorry if I was not so clear...
>>>> > Thank you in advance for your help
>>>> > Cheers
>>>> > _
>>>> > _______________________________________________
>>>> > Qgis-user mailing list
>>>> > Qgis-user at lists.osgeo.org
>>>> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>>> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210820/c19b4d13/attachment-0001.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210820/c19b4d13/attachment-0001.jpe>
