[Qgis-user] Issue extracting Strahler order from QGIS saved DEM
Nicolas Cadieux
njacadieux.gitlab at gmail.com
Fri Aug 20 10:11:30 PDT 2021
"Nicolas the problem with saving the raster using QGIS processes is the
resampling when converting sgrd to tif"
That was my conclusion also but//I was trying to figure out if this was
a bug or not. If you use the temporary file created as is, it works well.
Thanks!
Nicolas
On 2021-08-20 11:23 a.m., Luis Eduardo wrote:
> Very true John, that's another detail, some algorithms need a
> cartographic projection to work, for example upslope area.
> resampling when converting sgrd to tif, if you perform the same
> process as temporary it does not fail.
> On Friday, August 20, 2021, 11:02:40 AM GMT-4, Nicolas Cadieux
> <njacadieux.gitlab at gmail.com> wrote:
> Hi,
> When you save the file, are you changing the crs? If the ordinal DEM
> is in meters and the exported file in long last, the algorithm could
> go funny on you as some algorithms need files that are in meters to
> work well.
> Btw, would you be using saga in processing to do this? Is so. I have
> had a problem in the past where I could use a tiff, fill the sinks and
> then extract streams all in one shot. But if I saved the fill sink
> file and tried to use it later, I would get unusual results in th
> stream. If you have this problem, we should file a bug report.
> Nicolas Cadieux
> https://gitlab.com/njacadieux <https://gitlab.com/njacadieux>
>> Le 20 août 2021 à 06:44, johnboyd at netspace.net.au a écrit :
> Hi All, I am relatively new to GIS and was hoping for some help with a
> problem I have.
> When I load a DEM (tiff) file from an external source and fill sinks I
> can extract the Strahler order without issue. However after I save the
> file using the QGIS export feature and attempt to extract the Strahler
> order there is an issue where I appear to just get many short streams
> that don’t connect. Looking at the layer attributes between the
> unsaved file and the saved one they appear identical.
> I would appreciate some suggestions as it is frustrating not being
> able to save the updated DEM so it works.
> Regards
> John
> Qgis-user mailing list
> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
> <https://lists.osgeo.org/mailman/listinfo/qgis-user>
Nicolas Cadieux
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210820/ac19796c/attachment-0001.html>
