[Qgis-user] Selecting Multiple Layers in a Single Click
Charles Dixon-Paver
charles at kartoza.com
Fri Aug 20 14:06:10 PDT 2021
No, it's not a single click operation (qgis has no way to know how many
layers you want to choose). But you can use the "shift" and "ctrl"
techniques I mentioned before and click the "toggle selection" to simplify
checking multiple layers in those interfaces.
I often use the "select all" option and use the CTRL+click to deselect
unwanted layers. That makes it quicker when selecting the majority of large
layer collections.
On Fri, 20 Aug 2021, 22:48 krishna Ayyala, <ayyalakrishna at gmail.com> wrote:
> Charles,
> Thanks a lot for your reply. Is it possible to select the first four
> layers in a Single click in the following window?
> Regards.
> [image: image.png]
> On Fri, Aug 20, 2021 at 2:34 PM Charles Dixon-Paver <charles at kartoza.com>
> wrote:
>> You can select multiple layers by selecting the first layer and holding
>> SHIFT, then all the other layers between those two selected should also be
>> selected.
>> You can hold the CTRL button and click a layer to toggle it's selected
>> status to add or remove it from the selection.
>> You can then add them to a group or drag their order on the ToC, but to
>> toggle all layer visibility you will need to use the hide/ show selected
>> features option from the layer visibility drop down in the layer panel.
>> To my knowledge you can also only apply operations such as pasting of
>> layer styles to an individual layer, so the option will be applied to the
>> layer which you clicked to being up the context options and not all layers
>> in the selection.
>> Also, only the last layer selected will be marked as the currently
>> "active" layer when using operations like iface.activeLayer() from pyqgis.
>> On Fri, 20 Aug 2021, 22:22 krishna Ayyala, <ayyalakrishna at gmail.com>
>> wrote:
>>> Hello,
>>> I have 8 layers as below. Is it possible to select the first four layers
>>> in a Single click without having to manually select each layer?
>>> Regards.
>>> [image: image.png]
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210820/71de0771/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210820/71de0771/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210820/71de0771/attachment-0003.png>
