[Qgis-user] Selecting Multiple Layers in a Single Click
krishna Ayyala
ayyalakrishna at gmail.com
Fri Aug 20 13:48:32 PDT 2021
Charles,
Thanks a lot for your reply. Is it possible to select the first four layers
in a Single click in the following window?
Regards.
[image: image.png]
On Fri, Aug 20, 2021 at 2:34 PM Charles Dixon-Paver <charles at kartoza.com>
wrote:
> You can select multiple layers by selecting the first layer and holding
> SHIFT, then all the other layers between those two selected should also be
> selected.
> You can hold the CTRL button and click a layer to toggle it's selected
> status to add or remove it from the selection.
> You can then add them to a group or drag their order on the ToC, but to
> toggle all layer visibility you will need to use the hide/ show selected
> features option from the layer visibility drop down in the layer panel.
> To my knowledge you can also only apply operations such as pasting of
> layer styles to an individual layer, so the option will be applied to the
> layer which you clicked to being up the context options and not all layers
> in the selection.
> Also, only the last layer selected will be marked as the currently
> "active" layer when using operations like iface.activeLayer() from pyqgis.
> On Fri, 20 Aug 2021, 22:22 krishna Ayyala, <ayyalakrishna at gmail.com>
> wrote:
>> Hello,
>> I have 8 layers as below. Is it possible to select the first four layers
>> in a Single click without having to manually select each layer?
>> Regards.
>> [image: image.png]
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210820/e54d2fcd/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210820/e54d2fcd/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210820/e54d2fcd/attachment-0003.png>
