[Qgis-user] PyGQIS output a layer? v3.16
Etienne Trimaille
etienne.trimaille at gmail.com
Wed Aug 25 04:27:07 PDT 2021
A QgsProcessingOutputVectorLayer will understand you are returning a
QgsVectorLayer.
Maybe I'm wrong, but it works well :
https://github.com/3liz/QuickOSM/blob/master/QuickOSM/quick_osm_processing/advanced/open_osm_file.py#L130..L158
Le mer. 25 août 2021 à 11:59, Richard Duivenvoorde <rdmailings at duif.net> a
écrit :
> On 8/25/21 8:43 AM, Etienne Trimaille wrote:
> > You can output a QgsVectorLayer :
> https://qgis.org/api/classQgsProcessingOutputVectorLayer.html <
> https://qgis.org/api/classQgsProcessingOutputVectorLayer.html>
> > The sink is not required and you would avoid a loop to insert all
> features.
> > I think you should also return sink ID or layer ID, not the object
> itself.
> Hi Etienne,
> But the code of Andrew would receive features from a ArcGis feature
> server.
> How would you instruct QgsProcessingOutputVectorLayer to use that provider?
> QgsProcessing::SourceType shows (to me) only general types?
> Or is there some way to use it as a wrapper around a real layer?
> Regards,
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210825/1fadd0f0/attachment.html>
