[Qgis-user] OpenStreetMap Standard XYZ WMS exported to PDF is too small
Greg Troxel
gdt at lexort.com
Wed Aug 25 06:43:17 PDT 2021
Hugh Kelley <hghklly at gmail.com> writes:
> Is it possible that some settings in the OSM tile server have recently
> changed?
Anything is possible but if you mean the "Standard" layer at
https://www.openstreetmap.org/
which fetches from
https://tile.openstreetmap.org/
then I have been using that for editing the map and I have not noticed
significant changes or any wailing and gnashing of teeth about changes.
(BTW, use of OSM tiles should comply with the tile usage policy:
https://operations.osmfoundation.org/policies/tiles/
but that's not new.)
> I have noticed (maybe over the last few months) that the labels are very
> small, similar to what Bruno is describing and I believe that I had
> previously not noticed this as a problem, which makes me wonder whether
> something has changed.
Do you mean they look smaller when you look at them on
openstreetmap.org, or when rendered at ? dpi to PDF by qgis?
> Here is a helpful resource for exploring free xyz tile options from a
> variety of sources:
> https://leaflet-extras.github.io/leaflet-providers/preview/
Interesting link. Clicking around, the label sizes seem generally similar.
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210825/3246b621/attachment.sig>
