[Qgis-user] Axes
    Marcio Midon
    marciomidon at gmail.com
    Fri Aug 27 08:08:27 PDT 2021
TNX for all Charles.
Best regards,
Marcio Midon.
Em 26/08/2021 16:37, Charles Dixon-Paver escreveu:
> I think the best approach will greatly depend on your input data
> structure and situation, but I should think it certainly is possible.
> In the processing toolbox, there is a GRASS tool called
> v.voronoi.skeleton which is pretty effective at producing single
> centerlines from polygons. If what you want is not achievable with a
> single tool, the modeler will allow you to chain processing steps to
> achieve that outcome, likely in a much more effective manner than in
> the article you linked to. There may also be community built
> processing models available on GitHub or GIS stack exchange which
> might already do this for you. We are hoping to get more solutions on
> the https://plugins.qgis.org/models/
> <https://plugins.qgis.org/models/> platform so that this type of
> content is more discoverable in future.
> I hope that's at least enough to help you get started.
> Regards
> On Thu, 26 Aug 2021 at 19:05, Marcio Midon <marciomidon at gmail.com
> <mailto:marciomidon at gmail.com>> wrote:
>     hi Charles,
>     It's something like this:
>     https://support.esri.com/en/technical-article/000012414
>     <https://support.esri.com/en/technical-article/000012414>
>     But i just work with QGIS and Linux,
>     Thanks for all,
>     Best Regards,
>     Marcio Midon.
>     Em 26/08/2021 08:44, Charles Dixon-Paver escreveu:
>>     Hi there,
>>     I think it may be a bit unclear exactly what your objective is.
>>     Perhaps attaching an illustration of some sort would help the
>>     community better understand the problem so that we can assist
>>     with a solution.
>>     Regards
>>     On Thu, 26 Aug 2021 at 02:06, Marcio Midon <marciomidon at gmail.com
>>         Hello colleagues,
>>         I need to generate in QGIS street axes from a block face and
>>         that these axes cross for two meters.
>>         It's possible?
>>         Best regards,
>>         *Márcio Midon*Arquiteto e Urbanista UFPel Especialista
>>         Geoprocessamento UFPR Mestre Geomática UFSM Doutorando
>>         Geografia UFSM Tel 53 3305 7075 | Cel 53 98100 2020 SKYPE
>>         marcio_midon
>>         _______________________________________________
>>         Qgis-user mailing list
>>         Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>>         List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>>         <https://lists.osgeo.org/mailman/listinfo/qgis-user>
>>         Unsubscribe:
>     Cordialmente,
>     Geoprocessamento UFPR Mestre Geomática UFSM Doutorando Geografia
>     UFSM Tel 53 3305 7075 | Cel 53 98100 2020 SKYPE marcio_midon
Matrícula Aluno Especial
Cordialmente,
*Márcio Midon*Arquiteto e Urbanista UFPel Especialista Geoprocessamento
UFPR Mestre Geomática UFSM Doutorando Geografia UFSM Tel 53 3305 7075 |
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210827/13c6d134/attachment.html>
