[Qgis-user] Line dissolve
    Nicolas Cadieux
    njacadieux.gitlab at gmail.com
    Sun Aug 29 08:17:55 PDT 2021
Yes, Harrissou,
That does not work with lines unfortunately. I tried multiple times with different combinations.  It works with polygons when common borders need to be dissolved. I did see a merge function but did not find the line_merge plugin in  the repository. I figured it was QGIS2 and had been dropped.  Do you have any info of this?
Nicolas Cadieux
https://gitlab.com/njacadieux
> Le 29 août 2021 à 00:53, DelazJ <delazj at gmail.com> a écrit :
> Hi Nicolas,
> What about using "Dissolve" and then "multiparts to singleparts"...
> There's also the line_merge function, if you want to go the expression route.
> Regards,
> Harrissou
> Le 29 août 2021 05:26:24 GMT+02:00, Nicolas Cadieux <njacadieux.gitlab at gmail.com> a écrit :
>> Hi,
>> Just to clarify, I have no attribute to dissolve the lines on… so If you have as easy way to create an attribute list of all connected lines groups, I would also appreciate it.  This is easy in strait python but I am making a model and trying to rely on existing algorithms.
>> Thanks!
>> Nicolas Cadieux
>>>> Le 28 août 2021 à 20:21, Nicolas Cadieux <njacadieux.gitlab at gmail.com> a écrit :
>>> Hi,
>>> Is there an easy way, in processing, to dissolve lines that are touching? Alternative, can I create a multilinestring with all the lines that are touching?  Seems this should be a basic tool to have in QGIS…
>>> Nicolas Cadieux
> Envoyé de mon appareil Android avec Courriel K-9 Mail. Veuillez excuser ma brièveté.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210829/e4fdd89b/attachment.html>
