[Qgis-user] Line dissolve
DelazJ delazj at gmail.com
Sat Aug 28 21:52:57 PDT 2021
Hi Nicolas,
What about using "Dissolve" and then "multiparts to singleparts"...
There's also the line_merge function, if you want to go the expression route.
Regards,
Harrissou
Le 29 août 2021 05:26:24 GMT+02:00, Nicolas Cadieux <njacadieux.gitlab at gmail.com> a écrit :
>Hi,
>Just to clarify, I have no attribute to dissolve the lines on… so If you have as easy way to create an attribute list of all connected lines groups, I would also appreciate it.  This is easy in strait python but I am making a model and trying to rely on existing algorithms.
>Thanks!
>Nicolas Cadieux
>https://gitlab.com/njacadieux
>> Le 28 août 2021 à 20:21, Nicolas Cadieux <njacadieux.gitlab at gmail.com> a écrit :
>> Hi,
>> Is there an easy way, in processing, to dissolve lines that are touching? Alternative, can I create a multilinestring with all the lines that are touching?  Seems this should be a basic tool to have in QGIS…
>> Nicolas Cadieux
Envoyé de mon appareil Android avec Courriel K-9 Mail. Veuillez excuser ma brièveté.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210829/f36a0abd/attachment.html>
