[Qgis-user] Odp: Re:  (no subject)
    takacsviki
    takacsviki at o2.pl
    Sun Aug 29 10:34:54 PDT 2021
Dear Zoltan!   Nagyon szepen koszonom!   I will try this browser option. It can be a problem with the servers (it is a public domain). Half of the WMS is simply not working, might be a problem with the server indeed. Previously it was not a problem, now I see apart from orthophoto maps hardly anything is possible to get.   Thanks a  lot; Viktoria
        Dnia 29 sierpnia 2021 09:57 Zoltán Siki <siki1958 at gmail.com> napisał(a):
         Dear Viktoria,  I think the problem is with the network connection or the URL. Do you want to connect a public server?  Can you access the net? What if you type in the browser the URL of the WMS server plus "?service=wms&request=GetCapab You should get an XML. Until you don't get this XML QGIS won't work.  Regards, Zoltan   takacsviki <   takacsviki at o2.pl > ezt írta (időpont: 2021. aug. 27., P, 12:39):  Hi all!   Please help me!! I installed QGIS 3.16. When trying to add a VMS layer, it returns me the following message:    Nie powiodło się pobranie Capabilities:Pobieranie "capabilities" nie powiodło się: Dostęp do sieci wyłączony. =   download CApabilities was unsuccessful, the network access is switched off.    Should I configure somewhere network connection? What to do and how? Previously I have used several versions of QGIS but never had similar problems.    Thanks for the help!   Viktoria   ______________________________
Qgis-user mailing list
   Qgis-user at lists.osgeo.org
List info:  lists.osgeo.org lists.osgeo.org
Unsubscribe:  lists.osgeo.org lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210829/e18ea780/attachment.html>
