[Qgis-user] QGIS 3.20 odense freezing, ubuntu error messages
    Charles Dixon-Paver
    charles at kartoza.com
    Mon Aug 30 13:50:46 PDT 2021
Hey there, step one for troubleshooting is that you can try a new user
profile.
To create a new profile, go to Settings >> User Profiles >> New User Profile
Alternatively you can remove your existing user profile from the
home directory (on ubuntu usually
~/.local/share/QGIS/QGIS3/profiles/yourprofilename/). You can also find it
by using Open Active Profile Folder from the user profile menu in QGIS.
User profiles store configuration, plugins, and other user specific
settings and resources, so resetting tends to fix most issues.
Profiles are distinct from the QGIS version, so you could, for example,
have a plugin or resource not compatible with the newer QGIS version and
removing it would help resolve your stability problems. There is always a
chance that something else is wrong, but it's a good place to start.
Regards
On Mon, 30 Aug 2021 at 19:27, abisheridee <abisheridee at googlemail.com>
wrote:
> Hi all,
> I hope you can help me, I'm only a shallow user of QGIS but I'm in the
> middle of writing my thesis and really need to produce some maps!!
> I use ubuntu 20.04, and when I opened QGIS for the first time in a while I
> saw it had updated. Version 3.16 worked perfectly and I had little to no
> freezing problems. However now it's totally unusable, freezes immediately
> on opening a layer or even browsing files to open. I've tried uninstalling,
> purging, and reinstalling but that doesn't seem to work.
> When I ask ubuntu to update I get this error, even after I've
> uninstalled/purged QGIS
> "N: Skipping acquisition of configured file 'main/binary-i386/Packages',
> as repository 'https://qgis.org/ubuntu focal InRelease' doesn't support
> architecture 'i386'
> N: Skipping acquisition of configured file 'main/binary-i386/Packages', as
> repository 'https://qgis.org/debian focal InRelease' doesn't support
> architecture 'i386'"
> To install I follow the instructions on the QGIS site so I'm not doing
> anything weird. This all started after the automatic update. Please let me
> know if you need more info, I'm not confident with any of this so please
> explain to me like I'm an idiot.
> Thanks
> Abi
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210830/b2c317ac/attachment.html>
