[Qgis-user] Line dissolve
Nicolas Cadieux
njacadieux.gitlab at gmail.com
Mon Aug 30 15:57:11 PDT 2021
Thanks Charles,
This will be very useful. Nice to know I'am not the only one going crazy
with this!!!
Nicolas
On 2021-08-30 4:42 p.m., Charles Dixon-Paver wrote:
> I thought this would be easily solved with an expression but sadly I
> haven't been able to get reliable results at all.
> My first thought was
> collect($geometry,filter:=intersects($geometry,geometry(@parent))) and
> when that didn't work I tried various aggregates and union operations
> to no avail. Something like this might be useful if you can get it
> into a usable form (I managed to get various multigeometries in the
> form you are looking for but wasn't able to do much with them and
> there seemed to be artifacts):
> collect_geometries(array_foreach(aggregate(layer:='lines',aggregate:='array_agg',expression:=$geometry,filter:=intersects($geometry,geometry(@parent))), at element))
> I was actually waiting for someone else to come up with a more elegant
> solution, but it would probably also be possible to identify
> intersecting features and get the minimum/ maximum feature id for
> intersecting features with this:
> aggregate:='min',
> expression:="fid",
> You could use that in the field calculator to create a field for
> "grouping" various intersecting features to dissolve on, however it's
> only going to identify the minimum of the currently intersecting
> features so you would need to iterate through the process multiple
> times. I can't think of an effective way to implement a "while"
> conditional either.
> It's a pretty clanky way to do it, but if you are really struggling I
> think it's possible.
> On Mon, 30 Aug 2021 at 22:10, Nicolas Cadieux
> <njacadieux.gitlab at gmail.com <mailto:njacadieux.gitlab at gmail.com>> wrote:
> Hi,
> Seems like the plugin is available so I will try it out. The
> ability to create multi-linestring out of any touching lines
> (touch here means intersects at the first or last node) would be
> nice to have it if I can include it in a model.
> My goal is for this model to work for anyone with a basic install
> of QGIS LTR or 3.20 with minimal efforts so I am trying to
> eliminate the need to rely on external plugins or scripts.
> This is also my first attempt with models. It’s a learning curve
> but I am having fun… I think this probably should have been a
> plugin but my knowledge of GUI programming is basically 0. That
> will be for a next project…
> Nicolas Cadieux
> https://gitlab.com/njacadieux <https://gitlab.com/njacadieux>
>> Le 30 août 2021 à 14:59, David Strip <qgis-user at stripfamily.net
>> <mailto:qgis-user at stripfamily.net>> a écrit :
>> I looked at the source for this plug-in and as far as I can
>> tell it only merges lines that meet at endpoints. It ignores
>> multi-lines, and only creates linestrings, so there are no
>> vertices of degree >2 (ie, no junctions/forks). Also, the plug-in
>> doesn't look for intersections between vertices (since it only
>> looks to merge endpoints.)
>> The StackExchange post appears to want multi-linestrings, which
>> gives forks and such. Is that what you need?
>> On 8/30/2021 5:27 AM, Nicolas Cadieux wrote:
>>> Hi,
>>> This is the plugin I was referring to. I don’t see it in the
>>> current plugins (experimental turned on) so I figured it’s QGIS
>>> 2 only.
>>> https://github.com/ArMoraer/QGISMergeLines
>>> <https://github.com/ArMoraer/QGISMergeLines>
>>> Nicolas Cadieux
> Qgis-user mailing list
> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
> <https://lists.osgeo.org/mailman/listinfo/qgis-user>
Nicolas Cadieux
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210830/5ff3f0e5/attachment.html>
