[Qgis-user] Line dissolve
Charles Dixon-Paver
charles at kartoza.com
Mon Aug 30 13:42:06 PDT 2021
I thought this would be easily solved with an expression but sadly I
haven't been able to get reliable results at all.
My first thought was
collect($geometry,filter:=intersects($geometry,geometry(@parent))) and when
that didn't work I tried various aggregates and union operations to no
avail. Something like this might be useful if you can get it into a usable
form (I managed to get various multigeometries in the form you are looking
for but wasn't able to do much with them and there seemed to be artifacts):
collect_geometries(array_foreach(aggregate(layer:='lines',aggregate:='array_agg',expression:=$geometry,filter:=intersects($geometry,geometry(@parent))), at element))
I was actually waiting for someone else to come up with a more elegant
solution, but it would probably also be possible to identify intersecting
features and get the minimum/ maximum feature id for intersecting features
with this:
aggregate:='min',
expression:="fid",
You could use that in the field calculator to create a field for "grouping"
various intersecting features to dissolve on, however it's only going to
identify the minimum of the currently intersecting features so you would
need to iterate through the process multiple times. I can't think of an
effective way to implement a "while" conditional either.
It's a pretty clanky way to do it, but if you are really struggling I think
it's possible.
On Mon, 30 Aug 2021 at 22:10, Nicolas Cadieux <njacadieux.gitlab at gmail.com>
wrote:
> Hi,
> Seems like the plugin is available so I will try it out. The ability to
> create multi-linestring out of any touching lines (touch here means
> intersects at the first or last node) would be nice to have it if I can
> include it in a model.
> My goal is for this model to work for anyone with a basic install of QGIS
> LTR or 3.20 with minimal efforts so I am trying to eliminate the need to
> rely on external plugins or scripts.
> This is also my first attempt with models. It’s a learning curve but I am
> having fun… I think this probably should have been a plugin but my
> knowledge of GUI programming is basically 0. That will be for a next
> project…
> Nicolas Cadieux
> https://gitlab.com/njacadieux
> Le 30 août 2021 à 14:59, David Strip <qgis-user at stripfamily.net> a écrit :
> I looked at the source for this plug-in and as far as I can tell it
> only merges lines that meet at endpoints. It ignores multi-lines, and only
> creates linestrings, so there are no vertices of degree >2 (ie, no
> junctions/forks). Also, the plug-in doesn't look for intersections between
> vertices (since it only looks to merge endpoints.)
> The StackExchange post appears to want multi-linestrings, which gives
> forks and such. Is that what you need?
> On 8/30/2021 5:27 AM, Nicolas Cadieux wrote:
> Hi,
> This is the plugin I was referring to. I don’t see it in the current
> plugins (experimental turned on) so I figured it’s QGIS 2 only.
> https://github.com/ArMoraer/QGISMergeLines
> Nicolas Cadieux
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210830/b161dfc4/attachment.html>
