[Qgis-user] Issue using Symbology Style
Burghardt.Scholle at stadt.wolfsburg.de
Tue Aug 31 23:00:34 PDT 2021
Hello Nuno,
I also often use the map units to get a scaled representation. To prevent the effects you describe, I always use the "Adjust Scaling Range" option (see wrench button on the right side of the selection dialog). There you can enter for example a minimum / maximum scale. The change of the feature size in the map then moves only within the specified scale range. If necessary, you have to try a little bit to get the appropriate values.
Hope this helps
Regards
Burghardt
________________________________________
Von: Qgis-user <qgis-user-bounces at lists.osgeo.org> im Auftrag von Alexandre Neto <senhor.neto at gmail.com>
Gesendet: Mittwoch, 1. September 2021 00:53
An: Nuno Manuel de Figueiredo de Santos Loureiro
Cc: QGIS User
Betreff: Re: [Qgis-user] Issue using Symbology Style
Hello Nuno,
When you use map units, it means that the symbols size will change with the scale. At some bigger map scales, they can be ao small that disappear, in other lower scales it can be too big to fit inside a small polygon.
Unless you have a particular reason to use map units, you are better with millimetres. A symbol with 2 mm will keep that size at all scales.
Alexandre Neto
User support
Www.qcooperative.net<http://Www.qcooperative.net>
A segunda, 30/08/2021, 23:13, Nuno Manuel de Figueiredo de Santos Loureiro <nlourei at ualg.pt<mailto:nlourei at ualg.pt>> escreveu:
Hello all,
I'm producing a LCLU map and I 've created Symbols with Colours and Font Markers. Units are always configured as 'Map Units'.
In some of the polygons the letters appear and disappear when the scale changes. The same happens when I prepare Layouts. Depending on the scale being used, the letters are either visible or invisible. This does not happen on all polygons. It only happens in some...
Can anyone give suggestions on the cause of this problem, and how to solve it?
Very grateful in advance!
Nuno
Qgis-user mailing list
Qgis-user at lists.osgeo.org<mailto:Qgis-user at lists.osgeo.org>
List info: https://lists.osgeo.org/mailman/listinfo/qgis-user<https://secure-web.cisco.com/1UBLSPYEUj92aquPJGopRSwYduCnzY_7K67TYmIycbrs27Z8zTKaOl7vNJ1B9NsmalovXlI5RfcK66ei34Q6vPR0b0f1BbHqpSOFdTqI7NTaEiEtscDV5mX1nXtaLJEU06m5VSphzKs5lGjWUI5aYUJs6yJ4IYkRIUXyv9Hjs6R1vscqH5oipG9vztBZ-U2PDZrT5Nf2l0BU1Cg0WyYRXOt8LZLrkTeChQ_pMjBCAy8plr-79Xn2NkRGqWUQjExw9ISKOu4Rv_Q2a84xg9mb11gtw7Nj_cd3lDcpeQNUFeo9cgRxZdh4MenNowgrxXhUqzQRAEtLSUff6EFGkk5tvKQ/https%3A%2F%2Flists.osgeo.org%2Fmailman%2Flistinfo%2Fqgis-user>
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user<https://secure-web.cisco.com/1UBLSPYEUj92aquPJGopRSwYduCnzY_7K67TYmIycbrs27Z8zTKaOl7vNJ1B9NsmalovXlI5RfcK66ei34Q6vPR0b0f1BbHqpSOFdTqI7NTaEiEtscDV5mX1nXtaLJEU06m5VSphzKs5lGjWUI5aYUJs6yJ4IYkRIUXyv9Hjs6R1vscqH5oipG9vztBZ-U2PDZrT5Nf2l0BU1Cg0WyYRXOt8LZLrkTeChQ_pMjBCAy8plr-79Xn2NkRGqWUQjExw9ISKOu4Rv_Q2a84xg9mb11gtw7Nj_cd3lDcpeQNUFeo9cgRxZdh4MenNowgrxXhUqzQRAEtLSUff6EFGkk5tvKQ/https%3A%2F%2Flists.osgeo.org%2Fmailman%2Flistinfo%2Fqgis-user>
