[Qgis-user] Issue using Symbology Style
Alexandre Neto
senhor.neto at gmail.com
Tue Aug 31 15:53:12 PDT 2021
Hello Nuno,
When you use map units, it means that the symbols size will change with the
scale. At some bigger map scales, they can be ao small that disappear, in
other lower scales it can be too big to fit inside a small polygon.
Unless you have a particular reason to use map units, you are better with
millimetres. A symbol with 2 mm will keep that size at all scales.
Alexandre Neto
User support
Www.qcooperative.net
A segunda, 30/08/2021, 23:13, Nuno Manuel de Figueiredo de Santos Loureiro <
nlourei at ualg.pt> escreveu:
> Hello all,
> I'm producing a LCLU map and I 've created Symbols with Colours and Font
> Markers. Units are always configured as 'Map Units'.
> In some of the polygons the letters appear and disappear when the scale
> changes. The same happens when I prepare Layouts. Depending on the scale
> being used, the letters are either visible or invisible. This does not
> happen on all polygons. It only happens in some...
> Can anyone give suggestions on the cause of this problem, and how to solve
> it?
> Very grateful in advance!
> Nuno
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210831/5ad57f6d/attachment.html>
