[Qgis-user] QGIS: Export Metadata from postgis tables to shp?
    celati Laurent
    laurent.celati at gmail.com
    Wed Dec  1 12:27:58 PST 2021
Thanks a lot for your really usefull reply.
I just make a try and it works well.
Now, i have to make a test/check with metadata produced with the plugin
pgmetadata.
Le mer. 1 déc. 2021 à 16:52, DelazJ <delazj at gmail.com> a écrit :
> Hi Laurent,
> Starting from 3.20, you may want to test
> https://qgis.org/en/site/forusers/visualchangelog320/index.html#feature-persist-layer-metadata-in-vector-file-exports
> if I understand your need.
> Regards,
> Harrissou
> Le mer. 1 déc. 2021 à 16:16, celati Laurent <laurent.celati at gmail.com> a
> écrit :
>> Good afternoon,
>> With qgis, the description of a data seems to be available for filling
>> and consultation via the 'information' and 'metadata' tabs in "LAYER
>> PROPERTIES". There seem to be bridges between postgis and qgis. For
>> example, when I fill the "Comment" field of a table with pgadmin, the
>> content of the description is visible with qgis in the "Information" menu
>> in the Comment line and in the Abstract line. The description is also
>> visible in the "Metadata" menu in the Summary section / Identification tab.
>> For some postgis tables, I have also described the data thanks to the
>> usefull Pgmetadata plugin.
>> My need would be to be able to export these different data descriptions
>> during exports from these postgis tables toward files in shp format for
>> example. That these descriptions be kept during the export. Is it possible?
>> If yes, which tools / resources would exist?
>> Thanks a lot.
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20211201/da31d395/attachment.html>
