[Qgis-user] QGIS: Export Metadata from postgis tables to shp?
    DelazJ
    delazj at gmail.com
    Wed Dec  1 07:52:02 PST 2021
Hi Laurent,
Starting from 3.20, you may want to test
https://qgis.org/en/site/forusers/visualchangelog320/index.html#feature-persist-layer-metadata-in-vector-file-exports
if I understand your need.
Regards,
Harrissou
Le mer. 1 déc. 2021 à 16:16, celati Laurent <laurent.celati at gmail.com> a
écrit :
> Good afternoon,
> With qgis, the description of a data seems to be available for filling and
> consultation via the 'information' and 'metadata' tabs in "LAYER
> PROPERTIES". There seem to be bridges between postgis and qgis. For
> example, when I fill the "Comment" field of a table with pgadmin, the
> content of the description is visible with qgis in the "Information" menu
> in the Comment line and in the Abstract line. The description is also
> visible in the "Metadata" menu in the Summary section / Identification tab.
> For some postgis tables, I have also described the data thanks to the
> usefull Pgmetadata plugin.
> My need would be to be able to export these different data descriptions
> during exports from these postgis tables toward files in shp format for
> example. That these descriptions be kept during the export. Is it possible?
> If yes, which tools / resources would exist?
> Thanks a lot.
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20211201/69c9ae0b/attachment.html>
