[Qgis-user] Changing default pop-up attribute when using Identify tool
    Bernd Vogelgesang
    bernd.vogelgesang at gmx.de
    Wed Dec  8 13:32:50 PST 2021
I doubt that there is a simple way to change the behaviour of the
identify tool.
Recently, I came up with an idea how to quickly display whatever value
or even calculations by circumventing the identify tool but use a
special label setting and using the select tool.
Have a look here: https://gis.stackexchange.com/a/416224/8202
This example is about showing the area of a selected polygon, but
instead of the formula, you can put in every attribute of a layer.
Cheers,
Bernd
Am 08.12.21 um 21:01 schrieb Holly McLachlan:
> Is there a simple way to change the attribute table record that is
> automatically displayed in the right side pop-up panel when using the
> identify tool. I'm trying to single out a point feature in a point
> shapefile with a large set of attributes. I want to see only one
> associated row from the attribute table -- one that displays soil Li
> values in ppms. Currently the panel that pop ups on the right side of
> the map viewer shows these data under the "Action" sub-tree, but only
> for another row (record). I need to change the default record that is
> called by this tool.
> Thank you,
> Holly S Mclachlan
> (775) 762-3408
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20211208/f3e5aff5/attachment.html>
