[Qgis-user] Changing default pop-up attribute when using Identify tool
David Greenewalt
dlg at sover.net
Wed Dec 8 14:00:34 PST 2021
Double click on the layer to bring up layer properties, then find the
tab for "Display". At the top of the window is a field selection list.
This will set the value to display at the top of the identify window.
Hope this is what you're looking for.
David
On 12/8/2021 3:01 PM, Holly McLachlan wrote:
> Is there a simple way to change the attribute table record that is
> automatically displayed in the right side pop-up panel when using the
> identify tool. I'm trying to single out a point feature in a point
> shapefile with a large set of attributes. I want to see only one
> associated row from the attribute table -- one that displays soil Li
> values in ppms. Currently the panel that pop ups on the right side of
> the map viewer shows these data under the "Action" sub-tree, but only
> for another row (record). I need to change the default record that is
> called by this tool.
> Thank you,
> Holly S Mclachlan
> (775) 762-3408
> Qgis-user mailing list
> List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20211208/0b45955a/attachment.html>
