[Qgis-user] Bulk export atlas not working
    Dietrich Heintz
    dheintz at gmx.net
    Mon Dec 20 01:13:57 PST 2021
Hi Wouter,
would it be an option to uncheck "Single file export" and later merge
the documents into one?
ciao Dieter
On 20.12.2021 10:10, Wouter Impens wrote:
> Hi Dieter,
> You can export an atlas to a single pdf, with multiple pages. The QGIS
> function in the layout is working fine but when I try to automate the
> process, There's only a pdf with the last page. By watching the
> process, I can see that all the pages are made but they overwrite
> themselves.
> The output is configured like this:
> The automatisation with the 'maps printer plugin' used to work fine,
> It's not clear to me why it is not working now.
> Cheers
> Wouter
> Op ma 20 dec. 2021 om 10:00 schreef Dietrich Heintz <dheintz at gmx.net>:
>     Hello Wouter,
>     what do you mean with overwriting themselves. The Atlas needs a
>     value for the filename, which is derived from an entry of the
>     reference geometry?
>     ciao Dieter
>     On 20.12.2021 09:36, Wouter Impens wrote:
>>     Hi Hannes,
>>     Thanks for your answer.
>>     The names are unique. But the problem is not that one
>>     atlas layout is overwriting another, they're overwriting
>>     themselves. Ik only get the last page of each atlas.
>>     While the atlas is exporting, I can see in the windows
>>     explorer that a file is made and then reset to 0, only the last
>>     atlas page is kept.
>>     Greetings
>>     Wouter
>>     Op ma 20 dec. 2021 om 09:28 schreef Johannes Kröger (WhereGroup)
>>     <johannes.kroeger at wheregroup.com>:
>>         Hey Wouter,
>>         what is the atlas' expression for the filenames? Make sure
>>         they are unique, iterating and/or writing to a unique directory.
>>         Cheers, Hannes
>>         Am 18.12.21 um 18:51 schrieb Wouter Impens:
>>>         Dear list,
>>>         When using the ‘maps printer’ plugin for a bunch of atlas
>>>         layouts, the atlas pages are constantly overwritten by the
>>>         next page, so I end up with only the last page in the atlas
>>>         layout.
>>>         I used this before and it was working perfectly.
>>>         I also tried with the following script:
>>>         import qgis.core
>>>         layouts_list =
>>>         QgsProject.instance().layoutManager().printLayouts()
>>>         for layout in layouts_list:
>>>             QgsLayoutExporter.exportToPdfs(layout.atlas(),
>>>                                             'C:\\Users\\d08909\\Documents\\01_WERKMAP\\03_EXPORT\\',
>>>                                             QgsLayoutExporter.PdfExportSettings())
>>>         But it’s giving me the same result.
>>>         Manually exporting the altlas layouts one by one is no problem.
>>>         I’m using QGIS 3.16.14 on windows.
>>>         Any help is apreciated!
>>>         Kind regards,
>>>         Wouter Impens
>>     _______________________________________________
>>     Qgis-user mailing list
>>     Qgis-user at lists.osgeo.org
>>     List info:https://lists.osgeo.org/mailman/listinfo/qgis-user
>>     Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-user
>     _________________
>     Kronenbergstr. 7
>     CH-8800 Thalwil
>     +41 76 749 22 77
>     +41 43 540 90 71
>     my web-site <https://helgawittstock.wixsite.com/privat>
>     List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>     Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
_________________
Kronenbergstr. 7
CH-8800 Thalwil
+41 76 749 22 77
+41 43 540 90 71
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20211220/0a089bd2/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20211220/0a089bd2/attachment.png>
