[Qgis-user] Bulk export atlas not working
Wouter Impens wouter.impens at gmail.com
Mon Dec 20 09:04:44 PST 2021
Hi list,
I can solve the problem by making new layouts, the ones I was using were
made before updating QGIS and the plugin.
Just in case someone has the same problem...
Greetings
Wouter
Op ma 20 dec. 2021 om 10:14 schreef Dietrich Heintz <dheintz at gmx.net>:
> Hi Wouter,
> would it be an option to uncheck "Single file export" and later merge the
> documents into one?
> ciao Dieter
> On 20.12.2021 10:10, Wouter Impens wrote:
> Hi Dieter,
> You can export an atlas to a single pdf, with multiple pages. The QGIS
> function in the layout is working fine but when I try to automate the
> process, There's only a pdf with the last page. By watching the process, I
> can see that all the pages are made but they overwrite themselves.
> The output is configured like this:
> [image: image.png]
> The automatisation with the 'maps printer plugin' used to work fine, It's
> not clear to me why it is not working now.
> Cheers
> Wouter
> Op ma 20 dec. 2021 om 10:00 schreef Dietrich Heintz <dheintz at gmx.net>:
>> Hello Wouter,
>> what do you mean with overwriting themselves. The Atlas needs a value for
>> the filename, which is derived from an entry of the reference geometry?
>> ciao Dieter
>> On 20.12.2021 09:36, Wouter Impens wrote:
>> Hi Hannes,
>> Thanks for your answer.
>> The names are unique. But the problem is not that one atlas layout is
>> overwriting another, they're overwriting themselves. Ik only get the last
>> page of each atlas.
>> While the atlas is exporting, I can see in the windows explorer that a
>> file is made and then reset to 0, only the last atlas page is kept.
>> Greetings
>> Wouter
>> Op ma 20 dec. 2021 om 09:28 schreef Johannes Kröger (WhereGroup) <
>> johannes.kroeger at wheregroup.com>:
>>> Hey Wouter,
>>> what is the atlas' expression for the filenames? Make sure they are
>>> unique, iterating and/or writing to a unique directory.
>>> Cheers, Hannes
>>> Am 18.12.21 um 18:51 schrieb Wouter Impens:
>>> Dear list,
>>> When using the ‘maps printer’ plugin for a bunch of atlas layouts, the
>>> atlas pages are constantly overwritten by the next page, so I end up with
>>> only the last page in the atlas layout.
>>> I used this before and it was working perfectly.
>>> I also tried with the following script:
>>> import qgis.core
>>> layouts_list = QgsProject.instance().layoutManager().printLayouts()
>>> for layout in layouts_list:
>>>     QgsLayoutExporter.exportToPdfs(layout.atlas(),
>>>                                     'C:\\Users\\d08909\\Documents\\01_WERKMAP\\03_EXPORT\\',
>>>                                     QgsLayoutExporter.PdfExportSettings())
>>> But it’s giving me the same result.
>>> Manually exporting the altlas layouts one by one is no problem.
>>> I’m using QGIS 3.16.14 on windows.
>>> Any help is apreciated!
>>> Kind regards,
>>> Wouter Impens
>> Qgis-user mailing listQgis-user at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> _________________
>> Kronenbergstr. 7
>> CH-8800 Thalwil
>> +41 76 749 22 77
>> +41 43 540 90 71
>> my web-site <https://helgawittstock.wixsite.com/privat>
> _________________
> Kronenbergstr. 7
> CH-8800 Thalwil
> +41 76 749 22 77
> +41 43 540 90 71
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20211220/0f8c9c49/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20211220/0f8c9c49/attachment-0001.png>
