[Qgis-user] Space Syntax Toolkit
Alexandre Neto senhor.neto at gmail.com
Mon Feb 1 17:39:01 PST 2021
Yes, that is a good idea.
Good luck!
On Tue, Feb 2, 2021 at 1:37 AM Prof Maurizio Forte, Ph.D. <
maurizio.forte at duke.edu> wrote:
> Thanks I see it. Perhaps we should install it manually?
> *From:* Alexandre Neto <senhor.neto at gmail.com>
> *Sent:* Monday, February 1, 2021 8:14 PM
> *To:* Prof Maurizio Forte, Ph.D. <maurizio.forte at duke.edu>
> *Cc:* qgis-user at lists.osgeo.org
> *Subject:* Re: [Qgis-user] Space Syntax Toolkit
> Hi,
> That is really a question for the plugin developers. It seems they are
> still in active development, you can find the code here:
> https://github.com/SpaceGroupUCL/qgisSpaceSyntaxToolkit/blob/master/esstoolkit/metadata.txt
> <https://urldefense.com/v3/__https:/github.com/SpaceGroupUCL/qgisSpaceSyntaxToolkit/blob/master/esstoolkit/metadata.txt__;!!OToaGQ!-ql2PVyLH1APTUSIZ_D320LFpYka9Xd7bzNxK88b6HNtNJz1dMfagS5BvY_oOLpz5L7Q4w$>
> Best regards,
> Alexandre Neto
> On Mon, Feb 1, 2021 at 11:47 PM Prof Maurizio Forte, Ph.D. <
> Hello,
> I would like to test the Space Syntax Toolkit plugin in QGIS 3:10 but it
> seems it is not supported. Is there any new release of this plugin usable
> for the latest version of QGIS?
> thanks
> Maurizio Forte
> Qgis-user mailing list
> <https://urldefense.com/v3/__https:/lists.osgeo.org/mailman/listinfo/qgis-user__;!!OToaGQ!-ql2PVyLH1APTUSIZ_D320LFpYka9Xd7bzNxK88b6HNtNJz1dMfagS5BvY_oOLoW1pKNKg$>
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210202/a5263664/attachment.html>
