[Qgis-user] File based Geopackage bugs
Bernd Vogelgesang
bernd.vogelgesang at gmx.de
Tue Feb 2 06:06:52 PST 2021
for 2. I found a "workaround":
As far as I remember, copy/paste works, but when trying to save, you get
this warning/error.
In the attribute table, I pick the "fid" column, enter "$id" and perform
"update all". After that the layer can be saved.
A novice user will never come to that solution by itself, so this a real
show stopper for gpkg.
Am 02.02.21 um 03:11 schrieb Patrick Dunford:
> I recall going back someway we were sold this Geopackage idea being
> implemented into Qgis because it was going to be so much better than
> shape files that everyone has been using up to now. I bought into
> these ideas by converting shape files in most of my Qgis projects into
> Geopackage files.
> However there appear to be some serious bugs in Qgis' implementation
> of Geopackages as a file based system, and since SQlite has an
> impeccable reputation, it is a reasonable conclusion that there must
> be significant uncorrected bugs in the Qgis code that deals with file
> based Geopackages.
> Here are two examples:
> 1. Changing the data table associated with a layer, specifically the
> operation of deleting columns, is almost 100% guaranteed to result in
> automatic deletion of 100% of the features in the layer when the layer
> is saved. I have seen this happen multiple times, whether in a layer
> with 92 features or one with half a million.
> 2. Compared to shapefiles, Geopackages add an extra field called a fid
> which is a unique numerical value. For new records, this value is
> automatically generated. This requirement of uniqueness and the field
> apparently being unchangeable by the end user makes it impossible to
> paste features from another table if the values in the fid field for
> pasted features happen to coincide with existing entries in the table.
> These two examples are making me consider changing back to shapefiles
> in all my projects because shapefiles did not cause either of these
> two problems. Supposedly a shapefile is more prone to data corruption.
> This may be the case but as the code in Qgis that deals with
> shapefiles appears to be considerably more mature, these
> considerations have to be reasonably weighed against each other.
> Particularly in the case of issue 1, this appears to be a regression
> since I do not recall it being an issue on Qgis 2.18 or possibly
> earlier versions of Qgis 3. (I use the LTS edition of Qgis)
> Qgis-user mailing list
