[Qgis-user] File based Geopackage bugs
Patrick Dunford
enzedrailmaps at gmail.com
Tue Feb 2 14:15:59 PST 2021
I filed a bug report last week for the second problem, but it surely
must have been previously reported.
On 3/02/21 3:06 am, Bernd Vogelgesang wrote:
> for 2. I found a "workaround":
> As far as I remember, copy/paste works, but when trying to save, you get
> this warning/error.
> In the attribute table, I pick the "fid" column, enter "$id" and perform
> "update all". After that the layer can be saved.
> A novice user will never come to that solution by itself, so this a real
> show stopper for gpkg.
> Am 02.02.21 um 03:11 schrieb Patrick Dunford:
>> I recall going back someway we were sold this Geopackage idea being
>> implemented into Qgis because it was going to be so much better than
>> shape files that everyone has been using up to now. I bought into
>> these ideas by converting shape files in most of my Qgis projects into
>> Geopackage files.
>> However there appear to be some serious bugs in Qgis' implementation
>> of Geopackages as a file based system, and since SQlite has an
>> impeccable reputation, it is a reasonable conclusion that there must
>> be significant uncorrected bugs in the Qgis code that deals with file
>> based Geopackages.
>> Here are two examples:
>> 1. Changing the data table associated with a layer, specifically the
>> operation of deleting columns, is almost 100% guaranteed to result in
>> automatic deletion of 100% of the features in the layer when the layer
>> is saved. I have seen this happen multiple times, whether in a layer
>> with 92 features or one with half a million.
>> 2. Compared to shapefiles, Geopackages add an extra field called a fid
>> which is a unique numerical value. For new records, this value is
>> automatically generated. This requirement of uniqueness and the field
>> apparently being unchangeable by the end user makes it impossible to
>> paste features from another table if the values in the fid field for
>> pasted features happen to coincide with existing entries in the table.
>> These two examples are making me consider changing back to shapefiles
>> in all my projects because shapefiles did not cause either of these
>> two problems. Supposedly a shapefile is more prone to data corruption.
>> This may be the case but as the code in Qgis that deals with
>> shapefiles appears to be considerably more mature, these
>> considerations have to be reasonably weighed against each other.
>> Particularly in the case of issue 1, this appears to be a regression
>> since I do not recall it being an issue on Qgis 2.18 or possibly
>> earlier versions of Qgis 3. (I use the LTS edition of Qgis)
>> Qgis-user mailing list
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
