[Qgis-user] File based Geopackage bugs
Patrick Dunford
enzedrailmaps at gmail.com
Wed Feb 3 13:23:41 PST 2021
Hi Bernd
Thanks for your comments
As a previous commenter wrote, Spatialite also uses a similar format to
Geopackage being also based on SQLite.
So far in my testing of Spatialite I have found it to have neither
issue. Spatialite converted from Geopackage creates another field called
ogc_fid and ignores the fid field from the Geopackage. A test paste
resulted in the ogc_fid values being automatically updated to new ones
when the table is posted.
I dropped several columns in a table with 38,000 records and saw no data
loss with Spatialite, either.
I still have to test with 2.18 and the newest master to see how they
work with geopackage files before filing a bug report.
I guess a question is whether the server based implementation of
Geopackage has these issues.
On 3/02/21 3:06 am, Bernd Vogelgesang wrote:
> for 2. I found a "workaround":
> As far as I remember, copy/paste works, but when trying to save, you get
> this warning/error.
> In the attribute table, I pick the "fid" column, enter "$id" and perform
> "update all". After that the layer can be saved.
> A novice user will never come to that solution by itself, so this a real
> show stopper for gpkg.
