[Qgis-user] Georeferencing a DXF file
j.huber at post-ist-da.de j.huber at post-ist-da.de
Wed Feb 3 12:13:31 PST 2021
Hi Walt,
I would load the dxf file with the modified building in QCAD and
move/translate the data there. After saving the modified dxf file, this
should import in QGIS at the correct location.
You will need two reference points from the existing building structure
- you could for example export the existing data set from QGIS to dxf
and load it in QCAD as a reference or write the coordinates of two
points out manually in QGIS.
Regards
Jochen
Am 03.02.21 um 20:10 schrieb Walt Ludwick:
> I've received a 3D AutoCAD file from an architect that i managed to
> convert into 2D .dxf format and import into my QGIS project, but it is
> out-of-scale and out-of-place, so i guess i need to add some
> georeferencing coordinates to the file.
> This should be easy enough, since it's an accurate representation of a
> building that's already in the project -with an additional wing tacked
> on- so i'm thinking i could just use a few corners of that existing
> buildings as ground control points, and map them to the corresponding
> corners on this .dxf model, then maybe all other co-ordinates could be
> automatically generated by some tool, if i could just find the right
> one for the job.
> Is there in fact any such easy way to do this thing?
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210203/f86185eb/attachment.html>
