[Qgis-user] Georeferencing a DXF file
Jorge Gustavo Rocha jgr at geomaster.pt
Wed Feb 3 12:00:10 PST 2021
Hi Walt,
Some years ago, I used a plugin called "Vector bender" [1], but I have
no idea if it is still usable.
Please check if it runs on QGIS 3.x.
Regards,
Jorge Gustavo
[1]
https://www.cursosgis.com/georreferenciar-archivos-vectoriales-dxf-en-qgis/
Às 19:10 de 03/02/21, Walt Ludwick escreveu:
> I've received a 3D AutoCAD file from an architect that i managed to
> convert into 2D .dxf format and import into my QGIS project, but it is
> out-of-scale and out-of-place, so i guess i need to add some
> georeferencing coordinates to the file.
> This should be easy enough, since it's an accurate representation of a
> building that's already in the project -with an additional wing tacked
> on- so i'm thinking i could just use a few corners of that existing
> buildings as ground control points, and map them to the corresponding
> corners on this .dxf model, then maybe all other co-ordinates could be
> automatically generated by some tool, if i could just find the right
> one for the job.
> Is there in fact any such easy way to do this thing?
> Qgis-user mailing list
Email Signature
Logo <https://www.geomaster.pt>
*Geomaster*
*Jorge Gustavo Rocha* | Software Engineer
*e:*jgr at geomaster.pt | *m:*+351 910 333 888
*g:*41.54094,-8.40490 | *v: *510 906 109
*a: * Rua António Cândido Pinto, 67, 4715-400 Braga
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210203/09e42878/attachment.html>
