[Qgis-user] Detail-level of exported maps
Sebastian Gutwein
bas at rdgland.com
Fri Feb 5 06:24:28 PST 2021
Fred,
This is in my experience a limitation of the online basemaps. They are not
designed for printing.
As mentioned earlier you can use the map tiler plugin
https://www.maptiler.com/qgis-plugin/ to add vector tile maps. This has 2
advantages.
First if you print at 72 dpi the labels will still be crisp because they
are vectors. This does not help if you also have a raster layer because now
it will be low resolution.
Second you have control over the styles. This means you can make all of the
adjustment to label size in the style tab of the vector tile.
I have gone as far as creating a style with a project variable that I can
adjust the scale of the vector tile style tile at any point.
1.
First add tile_zoom_mag as a project property
2.
If you set iit to 1- you will see it as you would expect. For 150dpi
something like 2 might be better. If it is set to a high number in the map
and layout view before printing it will look wrong.
1.
To create the style I added @tile_zoom_mag * (original expression) in
front of all the size expressions for line work.
2.
For label size and lines that did not have an expression I used @value
*@tile_zoom_mag. This takes the currently set value and multiplies it by
the tile_zoom_mag variable.
-Bas
On Thu, Feb 4, 2021 at 8:01 AM Frederik Franke <frederik.franke at posteo.de>
wrote:
> Dear QGIS users,
> I’m relatively new to QGIS and need a quick help to export a map (as pdf)
> from the QGIS composer.
> My map contains an OpenStreetMap background map and I have the problem
> that the exported OpenStreetMap is much too detailed (e.g. hundreds of
> village names are included with a very small font size). When I change the
> export resolution from 300 dpi to 72 dpi in the composer I can circumvent
> this problem. Only big cities are labeled now and the city names are in an
> appropriate size. Unfortunately the map has a very bad resolution now (I
> can see single pixels when I set the pdf-zoom factor to 100 percent).
> How can I export a map with a lower detail-level but a good resolution?
> Thanks and best
> Fred
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210205/606dd2e6/attachment-0001.html>
