[Qgis-user] GRASS and UK LIDAR
    Alexis R.L.
    alroyliz0 at gmail.com
    Mon Feb  8 13:36:15 PST 2021
PROj might have changed and your file projection is unsupported anymore.
Transfer your layer to something less specific.
Alex
Le lun. 8 févr. 2021 à 14:57, Dave Marshall <43carnaby at gmail.com> a écrit :
> Hello,
> I use QGIS 3.4 to visualise LIDAR tiles from the UK which use EPSG:27700
> as the CRS. I put height contours on the images using the r.contour feature
> in GRASS. This works extremely well. I have tried a couple of times to move
> to a more up-to-date version of QGIS but in each case, the version of
> r.contour associated with later versions does not work. These later
> versions seem to require some sort of co-ordinate transformation on opening
> the LIDAR files (I think to EPSG:4326) and I wonder if this is part of the
> problem. Running r.contour generates an error message which seems to
> suggest it does not recognise or cannot work with the CRS being used (there
> is a reference to Airy Spheroid).
> What I would like to do is to be able to use a more up-to-date version of
> QGIS but with the same version of GRASS which I get when I use 3.4. This
> version would seem to be 7.6.1 rather than 7.8.5.
> There is a similar contour feature in QGIS under \Raster\Extraction but
> this does not allow the specification of height ranges which is essential
> for the work I am doing to avoid the routine from taking a very long time
> to run.
> Any help or advice would be much appreciated,
> Dave Marshall
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210208/90476052/attachment.html>
