[Qgis-user] open form with button
Stefan Giese Stefan.Giese at wheregroup.com
Mon Feb 8 23:11:28 PST 2021
Hi Raphael,
yes this is possible. But you will need to make your own custom form
with qt Designer (delivered with QGIS) and some python code. A good
starting point is the Blog from Nathan Woodrow, which is for QGIS 2.x
but the principle is almost the same. In the Python scripts you should
change the import statements to PyQt5 instead of PyQt4:
https://woostuff.wordpress.com/2011/09/05/qgis-tips-custom-feature-forms-with-python-logic/
also you will find a brief description on qgis.org:
https://docs.qgis.org/3.10/en/docs/training_manual/create_vector_data/forms.html#hard-fa-creating-a-new-form
Mit freundlichen Grüßen
Stefan Giese
Projektleiter/Consultant
Einladung zum
Mapbender Anwendertreffen
online am 25.03.2021
https://mapbender.org
WhereGroup GmbH
Schwimmbadstr. 2
79100 Freiburg
Germany
Fon: +49 (0)761 / 519 102 - 61
Fax: +49 (0)761 / 519 102 - 11
stefan.giese at wheregroup.com
www.wheregroup.com
Geschäftsführer:
Olaf Knopp, Peter Stamm
Amtsgericht Bonn, HRB 9885
Am 09.02.2021 um 08:01 schrieb Raphael d'Epagnier:
> Hello everyone
> I have already asked a similar question on this topic and received an
> answer that was very helpful and sufficient for the previous project,
> but I still need additional help.
> I have a point, line and area layer and an attribute table with
> detailed information about the respective geometry objects. In the
> attribute table, several objects of the different geometry types
> (point, line, area) can belong to the same object.
> The aim is that when I select a point, for example, the information
> from the attribute table is displayed (attribute table form opens
> instead of the point table form). A view is not an option as the data
> in the form needs to be editable. Is it possible to add a button or
> double-click to retrieve the information from the attribute table
> form? There is no problem if this opens a separate form or the
> attribute table form. I have attached a picture to explain my problem.
> Thanks for the help
> Best regards,
> Raphael
> Image
> *GeoplanTeam AG*
> Egliweg 6
> CH-2560 Nidau
> Image
> +41 (0) 32 332 78 00
> Image
> www.geoplanteam.ch<http://www.geoplanteam.ch/>
> Image
> raphael.depagnier at geoplanteam.ch<mailto:raphael.depagnier at geoplanteam.ch>
> Image
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210209/243ccfaa/attachment.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210209/243ccfaa/attachment.jpg>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210209/243ccfaa/attachment-0001.jpg>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210209/243ccfaa/attachment-0002.jpg>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210209/243ccfaa/attachment-0003.jpg>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210209/243ccfaa/attachment-0004.jpg>
Desc: OpenPGP digital signature
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210209/243ccfaa/attachment.sig>
