[Qgis-user] Support - representing a graph in Qgis
Giacomo Uguccioni
giacomo.uguccioni at gmail.com
Tue Feb 9 15:06:13 PST 2021
Thank you guys for the support.
Could I work with Graphviz in the python console inside Qgis? And does
Graphviz support shapefiles or similar as an input?
Il giorno mar 9 feb 2021 alle 20:07 Jorge Gustavo Rocha <jgr at geomaster.pt>
ha scritto:
> Hi,
> I second Chris's proposal. Using graphviz python module [1], you can
> generate your graph by iterating over the features.
> At the end, just call the render and you will get the rendered graph (just
> add view=True) within your QGIS environment. You need to know some Python
> basic stuff, but not much than the basic.
> Regards,
> Jorge Gustavo
> [1] https://graphviz.readthedocs.io/en/stable/manual.html
> Às 18:55 de 09/02/21, chris hermansen escreveu:
> Giacomo and list,
> On Tue, Feb 9, 2021 at 8:07 AM Giacomo Uguccioni <
> giacomo.uguccioni at gmail.com> wrote:
>> Hello everyone, and thanks for the support.
>> If this is not the place to ask for this kind of thing, I ask you to give
>> me a link where I could find support.
>> I'm a qgis 3.14 user. I would like to represent a tree diagram or
>> functional diagram being able to draw the symbology and position of nodes
>> and connections from the information contained in the attribute table.
>> Example: I would like to represent the medium voltage grid of a city as an
>> electrical diagram; I would like to represent with lines that join at nodes
>> the roads that connect certain houses and schools in a city. So my goal is
>> to be able to build a layout with symbology of nodes and connections
>> derived from information contained in different shapefiles or within
>> features, with a non-geographic but schematic / ideal criterion.
>> Do you have any ideas or suggestions on how to do it? I thank you for
>> every contribution.
> Not a QGIS-based solution, but I've used graphviz <https://graphviz.org/>
> to generate graphs from the command line with considerable success. It
> offers a small but useful programming language that can be combined with
> data in text files in a really useful way.
> Chris Hermansen · clhermansen "at" gmail "dot" com
> C'est ma façon de parler.
> Qgis-user mailing listQgis-user at lists.osgeo.org
> [image: Logo] <https://www.geomaster.pt>
> *Geomaster*
> *Jorge Gustavo Rocha* | Software Engineer
> *e:* jgr at geomaster.pt | *m:* +351 910 333 888
> *g:* 41.54094,-8.40490 | *v: * 510 906 109
> *a: * Rua António Cândido Pinto, 67, 4715-400 Braga
> <https://www.google.com/maps/search/Rua%0D%0A++++++++++++++++++++++++++Ant%C3%B3nio+C%C3%A2ndido+Pinto,+67,+4715-400+Braga?entry=gmail&source=g>
*Giacomo Uguccioni*
*Geospatial Data Acquisition & Processing*
+39 3920431219
Le informazioni contenute nella presente comunicazione sono riservate
esclusivamente ai destinatari indicati in epigrafe. La diffusione del
documento trasmesso da parte di qualsiasi soggetto diverso dal mittente e
dal destinatario è proibita, sia ai sensi dell’art. 616 c.p., sia ai
sensi del D.Lgs. n. 196/2003 e regolamento UE n. 2016/679.
Se avete ricevuto questo messaggio per errore, vi preghiamo di distruggerlo
e di darcene immediata comunicazione anche inviando un messaggio di ritorno
all’indirizzo e-mail del mittente.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210210/52f626a9/attachment.html>
