[Qgis-user] Support - representing a graph in Qgis
Giacomo Uguccioni giacomo.uguccioni at gmail.com
Wed Feb 10 04:02:28 PST 2021
Thanks a lot!
I would like to represent a shapefile or more shapefiles of nodes and
connections (lines and points)
in a layout similar to an electrical scheme, a symbolic and conceptual
scheme and not a geographical one.
I attached an image with qgis view and output that I would like to get.
Il giorno mer 10 feb 2021 alle ore 01:25 Jorge Gustavo Rocha <
jgr at geomaster.pt> ha scritto:
> Hi Giacomo,
> Maybe it is better to share a sketch of what you want.
> 0) From the description of your use case, you can use the geographic
> position of the nodes, right? You might be able to do what you want just by
> creating points where you want to show the grid voltage and then create
> direct lines between nodes. If you can display it on the map, you don't
> need a graph.
> 1) Yes, you can use graphviz in the python console.
> 2) Graphviz does not read shapefiles. You have to iterate over your layer
> and generate the corresponding graph nodes and edges.
> Regards,
> Jorge Gustavo
> Às 23:06 de 09/02/21, Giacomo Uguccioni escreveu:
> Thank you guys for the support.
> Could I work with Graphviz in the python console inside Qgis? And does
> Graphviz support shapefiles or similar as an input?
> Il giorno mar 9 feb 2021 alle 20:07 Jorge Gustavo Rocha <jgr at geomaster.pt>
> ha scritto:
>> Hi,
>> I second Chris's proposal. Using graphviz python module [1], you can
>> generate your graph by iterating over the features.
>> At the end, just call the render and you will get the rendered graph
>> (just add view=True) within your QGIS environment. You need to know some
>> Python basic stuff, but not much than the basic.
>> Regards,
>> Jorge Gustavo
>> [1] https://graphviz.readthedocs.io/en/stable/manual.html
>> Às 18:55 de 09/02/21, chris hermansen escreveu:
>> Giacomo and list,
>> On Tue, Feb 9, 2021 at 8:07 AM Giacomo Uguccioni <
>> giacomo.uguccioni at gmail.com> wrote:
>>> Hello everyone, and thanks for the support.
>>> If this is not the place to ask for this kind of thing, I ask you to
>>> give me a link where I could find support.
>>> I'm a qgis 3.14 user. I would like to represent a tree diagram or
>>> functional diagram being able to draw the symbology and position of nodes
>>> and connections from the information contained in the attribute table.
>>> Example: I would like to represent the medium voltage grid of a city as an
>>> electrical diagram; I would like to represent with lines that join at nodes
>>> the roads that connect certain houses and schools in a city. So my goal is
>>> to be able to build a layout with symbology of nodes and connections
>>> derived from information contained in different shapefiles or within
>>> features, with a non-geographic but schematic / ideal criterion.
>>> Do you have any ideas or suggestions on how to do it? I thank you for
>>> every contribution.
>> Not a QGIS-based solution, but I've used graphviz <https://graphviz.org/>
>> to generate graphs from the command line with considerable success.  It
>> offers a small but useful programming language that can be combined with
>> data in text files in a really useful way.
>> Chris Hermansen · clhermansen "at" gmail "dot" com
>> C'est ma façon de parler.
>> Qgis-user mailing listQgis-user at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
>> [image: Logo] <https://www.geomaster.pt>
>> *Geomaster*
>> *Jorge Gustavo Rocha* | Software Engineer
>> *e:* jgr at geomaster.pt | *m:* +351 910 333 888
>> *g:* 41.54094,-8.40490 | *v: * 510 906 109
>> *a: * Rua António Cândido Pinto, 67, 4715-400 Braga
>> <https://www.google.com/maps/search/Rua%0D%0A++++++++++++++++++++++++++Ant%C3%B3nio+C%C3%A2ndido+Pinto,+67,+4715-400+Braga?entry=gmail&source=g>
> *Giacomo Uguccioni*
> *Geospatial Data Acquisition & Processing*
> +39 3920431219
> Le informazioni contenute nella presente comunicazione sono riservate
> esclusivamente ai destinatari indicati in epigrafe. La diffusione del
> documento trasmesso da parte di qualsiasi soggetto diverso dal mittente e
> dal destinatario è proibita, sia ai sensi dell’art. 616 c.p., sia ai
> sensi del D.Lgs. n. 196/2003 e regolamento UE n. 2016/679.
> Se avete ricevuto questo messaggio per errore, vi preghiamo di
> distruggerlo e di darcene immediata comunicazione anche inviando un
> messaggio di ritorno all’indirizzo e-mail del mittente.
> *Geomaster*
*Giacomo Uguccioni*
+39 3920431219
Se avete ricevuto questo messaggio per errore, vi preghiamo di distruggerlo
e di darcene immediata comunicazione anche inviando un messaggio di ritorno
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210210/cbff7bc3/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210210/cbff7bc3/attachment-0001.png>
