[Qgis-user] Unreadable streetnames during export as image from print composer
    silvio.bentzien
    silvio.bentzien at protonmail.com
    Fri Feb 12 03:06:19 PST 2021
Hey,
that is a common thing to happen when exporting maps using a WM(T)S or Tile layer. This is due to the difference in DPI between your monitor (probably ~ 96dpi) and the exported map (probably ~300dpi).
Service layers will send you more tiles of a smaller scale instead of something that resembles what you see on your screen. A solution would be to use service layers that have a fixed scale. I'm not familiar with maptiler/pdok but if they have a layer for, let's say, 1:10000, then use this one if your map is 1:10000.
Hope this helps.
greetings,
silvio
‐‐‐‐‐‐‐ Original Message ‐‐‐‐‐‐‐
On Friday, February 12, 2021 11:54 AM, <ahullegie at gmail.com> wrote:
> I’m encountering an issue where the streetnames from maptiler/pdok services are barely visible on the exported image but are properly scaled when viewed in QGIS-composer. Can anyone recommend a fix for this?
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210212/06d615ca/attachment.html>
