[Qgis-user] Geometries of labels - automatic positioning (no covering)
silvio.bentzien
silvio.bentzien at protonmail.com
Fri Feb 12 03:49:23 PST 2021
Hey Matej,
please disregard my last message. I got lost in the thread.
Would it help your problem if you lock the scale of your project and use the Magnifier to zoom in and out? That way, you can lock the symbols and labels to the scale you want to plot your map in and you would have greater awareness and control over the placement of you labels. (assuming that changing label positions manually is feasible in your case)
greetings,
silvio
‐‐‐‐‐‐‐ Original Message ‐‐‐‐‐‐‐
On Thursday, February 11, 2021 3:08 PM, Matej Mailing <mailing at tam.si> wrote:
> Thanks, I already have this enabled.
> What I would like is to achieve this result (img1) instead now having
> labels covering each other as in img2.
> Thanks,
> Matej
> V V tor., 9. feb. 2021 ob 14:02 je oseba Matej Mailing
> mailing at tam.si napisala:
> > Thanks,
> > Matej
> > V V tor., 9. feb. 2021 ob 13:34 je oseba Richard Duivenvoorde
> > rdmailings at duif.net napisala:
> > > On 2/9/21 1:29 PM, Matej Mailing wrote:
> > > > Hello Regis,
> > > > I cannot find that option you mention: "the placement option "always
> > > > displays" on the layers"
> > > > I seem to have checked all the options - I am using QGIS 3.16.3.
> > > See screenshot, it is in the last tab, checkbox "Show all labels for this layer (including colliding labels)"
> > > Regards,
> > > Richard Duivenvorde
> Qgis-user mailing list
