[Qgis-user] Geometries of labels - automatic positioning (no covering)
Matej Mailing mailing at tam.si
Fri Feb 12 05:02:16 PST 2021
Hi Silvio.
Basically my issue is that I need to have all the symbols and labels
visible, but since the number of those is huge, I want to have the
need to place them automatically as much as possible. If somehow I
could use the collision engine to recalculate the positions -  I just
need the labels to be visible, the exact label position (little more
to the each side as it must be to avoid colliding) is not important, I
just need them to be visible near the objects basically...
Positioning every label by hand takes an enormous amount of time of
manual work that seems to be meaningless in the current state of
automation :)
Thanks,
Matej
V V pet., 12. feb. 2021 ob 12:49 je oseba silvio.bentzien
<silvio.bentzien at protonmail.com> napisala:
> Hey Matej,
> please disregard my last message. I got lost in the thread.
> Would it help your problem if you lock the scale of your project and use the Magnifier to zoom in and out? That way, you can lock the symbols and labels to the scale you want to plot your map in and you would have greater awareness and control over the placement of you labels. (assuming that changing label positions manually is feasible in your case)
> greetings,
> silvio
> ‐‐‐‐‐‐‐ Original Message ‐‐‐‐‐‐‐
> On Thursday, February 11, 2021 3:08 PM, Matej Mailing <mailing at tam.si> wrote:
> > Thanks, I already have this enabled.
> > What I would like is to achieve this result (img1) instead now having
> > labels covering each other as in img2.
> > Thanks,
> > Matej
> > V V tor., 9. feb. 2021 ob 14:02 je oseba Matej Mailing
> > mailing at tam.si napisala:
> > > Thanks,
> > > Matej
> > > V V tor., 9. feb. 2021 ob 13:34 je oseba Richard Duivenvoorde
> > > rdmailings at duif.net napisala:
> > > > On 2/9/21 1:29 PM, Matej Mailing wrote:
> > > > > Hello Regis,
> > > > > I cannot find that option you mention: "the placement option "always
> > > > > displays" on the layers"
> > > > > I seem to have checked all the options - I am using QGIS 3.16.3.
> > > > See screenshot, it is in the last tab, checkbox "Show all labels for this layer (including colliding labels)"
> > > > Regards,
> > > > Richard Duivenvorde
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
