[Qgis-user] Inserting a Simple Straight Line
Nicolas Cadieux
njacadieux.gitlab at gmail.com
Mon Feb 15 12:18:18 PST 2021
You also need to make sure that the layer is a line layer, not a polygon or point layer. First, select the line layer, place it in edit mode then follow the instructions below.
Nicolas Cadieux
https://gitlab.com/njacadieux
> Le 15 févr. 2021 à 15:08, Andrea Giudiceandrea <andreaerdna at libero.it> a écrit :
> Jon Fox wrote
>> I tried to insert a straight line by using
>> various combinations of right- or left-clicking, and by hitting the
>> "enter"
>> key, but the line keeps continuing on as if I can only make a polyline.
> Hi Jon,
> if I understand correctly your request, you just need to follow the rule for
> drawing lines in QGIS:
> - "left click" for the first (initial) point of the segment
> - "left click" for the second (final) point of the segment
> - "right click" to terminate the drawing of the line.
> Regards.
> Andrea
> Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-User-f4125267.html
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210215/46e40afe/attachment.html>
