[Qgis-user] Inserting a Simple Straight Line
Jon Fox
jon.fox at jonfoxpg.com
Mon Feb 15 12:23:00 PST 2021
OK, thank you Andrea and Nicolas for your help.
Regards,
Jon
From: Qgis-user <qgis-user-bounces at lists.osgeo.org> On Behalf Of Nicolas Cadieux
Sent: Monday, February 15, 2021 3:18 PM
To: Andrea Giudiceandrea <andreaerdna at libero.it>
Cc: qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] Inserting a Simple Straight Line
You also need to make sure that the layer is a line layer, not a polygon or point layer. First, select the line layer, place it in edit mode then follow the instructions below.
Nicolas Cadieux
https://gitlab.com/njacadieux
Le 15 févr. 2021 à 15:08, Andrea Giudiceandrea <andreaerdna at libero.it <mailto:andreaerdna at libero.it> > a écrit :
Jon Fox wrote
I tried to insert a straight line by using
various combinations of right- or left-clicking, and by hitting the
"enter"
key, but the line keeps continuing on as if I can only make a polyline.
Hi Jon,
if I understand correctly your request, you just need to follow the rule for
drawing lines in QGIS:
- "left click" for the first (initial) point of the segment
- "left click" for the second (final) point of the segment
- "right click" to terminate the drawing of the line.
Regards.
Andrea
Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-User-f4125267.html
Qgis-user mailing list
Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
List info: https://lists.osgeo.org/mailman/listinfo/qgis-user
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20210215/45cf37f2/attachment.html>
